My problems, ranked in order of severity (only the top 5 or 6 are a big deal):
1. - Hesitation. Flashed but only saw a small improvement. Car is still faster at 1/2 throttle than WOT. Car ALWAYS pulsates under constant throttle position.
2. - Stumble. If I take a slow 90 degree turn in 3rd or 4th gear, car will almost always "hiccup" or stumble at least once or twice as the RPMs climb -- almost always at 1.7k RPM. This is not normal - it's not the engine bogging, it's just flat out "missing" or stumbling.
3. - Rear suspension clunk (so far fixed with 1000 miles on E bushings).
4. - Coolant leaks. So far 3 different hoses have been "fixed" twice.
5. - Drivetrain "lash" or "lurch" when feathering the throttle at mild speeds or stop-and-go traffic. My 2000 ES even had this problem with the cruise control on!! When the cruise gave it gas, nothing would happen and then all of a sudden, POW, the whole drivetrain would "jump" and then I'd accelerate. Slowing down was the reverse affect - tranny would "jump" and then I'd slow down faster than normal while coasting. It would do this inconsitantly -- some trips it would do it, other times it wouldn't.
6. - Front suspension "crunch". Very loud in winter. Dealer says "it's a high performance car, they will make these noises, nothing I can do." That's BS because only the passenger's side does it for the most part. Rarely the driver's side.
7. - Radio twice "flipped out" and stayed there and wouldn't respond. Each time was "fixed" by not touching it and just shutting off and starting the car back up a few times.
8. - Stress crack in windshield after 1000 miles.
9. - Rear deck makes obscene rattle noise with or without music. Doesn't happen 100% of the time. Usually the worst when cold.
10. - Driver's window squeaks over bumpy roads - again no biggy.
11. - Driver's seat belt "pretensioner"/adjuster makes a "ticking" noise and squeaks. Very minor.
12. - Intermittent rattle noise coming from middle of gauge cluster - can stop it by putting pressure on top of guage cluster/dash. Rattles in general I don't have a problem with because it's almost impossible to design a car that doesn't rattle when it has to deal with the extreme tempurature changes here.
12. - Rusty rotor hubs as I drove off the dealer's lot. They won't paint them so I did myself.
13. - Shifter squeeks while shifting - again very minor. For some reason this went away for the winter. Hopefully it stays away.
14. - Compressor surge from factory. Up for debate whether it could cause a problem though.
15. - Clutch has too much damping. If I release the clutch semi-quickly, the clutch doesn't keep up with my foot. This is not an actual problem, just an annoyance I guess.
boss_hogg@***getridofthis***tznet.com
Thanks,
-Casey
