ok first question:
how do you get the nut off for the oil cooler? (the 'sandwhiche plate' between the crank case and the oil filter with coolant running through it)
the bolt that the oil filter screws on is too long to get even a deep socket around the nut, and its not a big enough opening for pliers =(
second question:
what material is the oil pan made out of?
and what material is the windage tray made out of?
I think the windage tray is alluminum, and the oil pan is steel....correct?
second question:
