2.0t03speed's MSP Build Thread
2.0t03speed
08.5 CWP Speed 3
Backstory: I bought my MSP in 2007 with 40k on the clock. Since i've owned it it's seen a variety of different mod's, motor's, and trany's here is what is currently on the car
Engine Mod's:
505Zoom Aluminum Intake Manifold
JayRacing Im & Tb Thermal Spacers
Perrin Fuel Rail
Custom Johnridinhi Grounding kit
JDM Intake Cam
Custom -4AN Oil Feed Line
Custom Adjustable ATP Wastegate
Custom 3" Intake w/ Apexi Filter
GT2871R .64A/R hotside w/ GT28R compact compressor housing
GHL Downpipe
3" under axle Exhaust w/ JIC Magic Muffler & Vibrant Ultra Quiet Resonator
Brushed Air Diversion Panel
CR3 Radiator Brackets
Mishimoto Radiator
Mishimoto Fan shroud w/ dual 12" fans
Signature Products Custom Valve Cover
Signature Products Coolant Catch Can
Signature Products Powersteering Fluid Reservoir
Signature Products vented oil catch can
Custom FMIC w/ 2.5" piping & 30x7.5x3" intercooler
NGR Type-S Bov
Suspension:
C-Tek Rotors Front/Back
C-Tek Pads
D2 RS Coilovers
Hkpro5 Front & Rear Endlinks
Carbing front strut tower bar
Cusco front lower tie bar
Drivetrain:
Exedy Stage 1 Clutch
Karboy Shifter Bushing's
Corksport Exhaust Hangers
TWM Shifter
Medieval Front MM
Medieval Rear MM
Awr Passenger Side Mount
Awr Transmission Mount
Interior:
MSP Production # Plate
Dave B Gauge Rings
Led interior lighting
Forcefed Radio surround w/ real CF Inlays
Alpine XDA-200 HU
Mazdaspeed Shift knob
redline goods shift boot (bride seat material)
Hkpro5 Column pod
8" Kicker Comp VR retrofitted into the stock msp sub enclosure
Exterior:
Retrofit headlights w/ Morimoto mini H1 projectors & 5k 55w hid's
Xcelerated Concepts Reverse Cowl Hood
Xcelerated Concepts CF Trunk
Isport CF Rear Window Visor
nk2a's Sag fix Brackets
JDP Replica Lip
Work Emotion XD-9 17x7.5 +37 front +39 rear
215/45/17 Hankook Ventus V12 evo K110's tires
Work RS black lug nuts
Ems:
Mpi Tuner w/ Extra injectors
J&S Safeguard
Joe P FCD
FM o2 Modifier
GM 3bar Map Sensor
AEM Failsafe gauge
Greddy Profec b ebc
HKS Type-0 Turbo Timer
Little update went and installed a set of rx-8 rims today with 5mm spacers in front and 3mm spacers in back. Looks pretty flush going to try and get some pictures tomorrow. Oh i also went and installed a set of polished gauge rings
Yeah those RX wheels look good Ryan.
Thanks man! the probe was looking good this past weekend too
Looks like you need to go a little lower in the rear.
lol i need to go lower all around. got 1 finger gap up front and 1.5 in the back. Im going to swap out my eibach sportlines with some coilovers as soon as possible.
they made the under axle exhaust in 2.5"? my friend had it on his car,...and his was def 3"
they had 2 version 2.5 and 3". i've owned both. Only thing is even with the 2.5" version the piece at the very end that has the muffler on it is 3".
subbin and lookin good. Thanks for leavin some of my old nittos if front of the house;)
:) i really like your car on those rx8s
Thanks man
hows that NGR BOV treating you?
pretty good i've had it on for a year or so now with one spring and no leaks/flutter. Just a constant blow off weather im in boost or vacuum
Great build (thumb) how did that 505 manifold feel when you installed it?
felt good still think its the best mod i've ever done to my car. I can't wait to see how it reacts to my MAM mani and 28rs when i put them on.
Latest posts
