BlackJack said:Do you mean the regular Mazda3, not the MS3?
Euphorism said:$300 is pretty cheap actually. if its a reputable place, and you arent comfortable doing it yourself, i would jump on it.
i didnt quite understand what you meant by passing on the eds for the tcsounds to save on trunk space.. the eds take less enclosure volume than the tc's do. ed used the tc9 motors on the flatcone a series subs from about 3 years ago. the current line up is more efficient and requires smaller enclosures.
krimsonviper said:o yeah and one more thing, its not really wise to run 0awg inside the car, its better to wire it underneath and using pins to keep it in place and then drilling a hole somewhere around the trunk region, but i figure its too much work therefore i didnt do it, plus i dont see a way around this method w/o having to use a drill
tsunami said:it is never safe to run power wire outside of your car where the elements and road debris can get to it and short out your wire.... i have never heard of anyone running thier wires outside of the cabin...
