I currently have the stock SMIC. I'd like to get a FMIC. What options do I have based on my needs?:
I want something that is less likely to soak up heat from engine bay, and has more cooling potential. Larger intercooler, and a front-mounted one, seems like the answer. However, I'd also like to have good air flow in the intercooler system. From a "sticky" I've read, I understand that FMICs can introduce extra turbo lag due to longer piping (when compared to the stock SMIC). Then there is the issue of intercoolers themselves that might have a crappy flow, or less than desired heat exchange properties.
Alright, so I'd like to have:
- front mounted one
- with short and no-restrictive piping
- intercooler has good heat exchange properties
- intercooler design being high-flow in itself
- fairly easy to install - would be a bonus
I probably can't have it all, but I'm hoping to find a compromise.
What's the end goal of this? More power, and with no (or with very little) additional lag.
My top budget amount? I don't know. lets say: $800. I mean, if I'm not the one to throw money away, or spend lots to gain little. So if I can get an intercooler for $500 that does 95% of one for $800, I'm getting the 500-dollar one. If I can spend less and get a good one, I'm in, but I don't want to end up getting something sub par, while saving a little, and then regretting it.
I have an Injen CAI currently installed, so the new FMIC has to work with/around that
Cork Sport IC looks interesting, but I know nothing about it or any other FMIC that's out there.
As you humans say, I'm all ears.
- front mounted one
