So is it bad to install 3 way rear speakers on a mazda3 sedan if i don't have tweeters in the front? Will it sound bad, because when i listen to music now, sometimes the voice is drowned out from the tremble and bass.
I dont know if your still around to get this answer but there are a few issues within the statement.
1. We have to identify what you mean by a 3-way system.
- A lot of marketing companies call a tri-axle speaker a three way when they glue 2 crappy tweeters to mid range speaker. My suggestion with these is to listen to the speakers first and evaulate how you like the sound. Do not even bother thinking about it being a 2-way vs a 3-way vs a 4-way. Speakers come down to how they sound to you and these terms are from marketing departments.
2. Tweeters are just a driver, they can be part of a component system, part of a triaxle or coaxle speaker or pruchased seperately. So no, you do not need a seperate tweeter in addition to whatever your front speakers are. They may already have a tweeter, its just not seperate from the mids.
Here is an example:
http://mobile.jlaudio.com/products_components.php?comp_id=491
These speakers have a tweeter mounted to the center of the midrange.
http://mobile.jlaudio.com/products_components.php?comp_id=490
These are the exact same tweeter and midrange, just seperated.
Adding that tweeter can make alot of system sound worse. This is what happens when people just start tossing speakers into a car ontop of each other. Speakers can counteract each other, and always will.
THe idea of installing new rear speakers and not touching the front is major no-no for most people in the audio industry that apprecieate good sound. The main reason is that when you watch a movie, go to a concert, or even watch TV, the sound comes from in front of you. So why spend money to put the best sound in the car behind you?
You can, its not right or wrong depending on the context, its jsut about what you want to achieve and what you think sounds good.
