Purchased brand new 2023 Carbon Edition CX5 with 5 miles on it. At approx 200 miles I took a pic of oil level on dip stick and the coolant level in expansion tank. The oil was right in between H and L, mid level. Coolant was at 1/2 inch above L level. All checked when cold.
Now, 4 months later and about 980 miles on car, I check the coolant and oil again. The oil level is same at midpoint H and L. However the coolant is now at exactly the L line. I checked every hose, connections, cap tightness , for any leaks but it all looks brand new. So how does a brand new car drop a half inch of coolant level? Car is always at mid level temperature or below on the temp guage .
I added pics I took today and the higher level coolant one was about 4 months ago. I am due for first service in 2 mos and wonder if I should just add FL22 coolant to the full line and keep watching coolant level until service is up and then let them check for coolant leaks.
Hoping someone might have some knowledge on this is as you would think a new car would not have any coolant loss at all. Thanks
