I was going to get this valve for the convenience factor, but not sure that's more important than getting all the old oil and fragments out. Your thoughts?
damn, i was charged extra for that !!!Besides, you don't have to buy the drain plug - it's included with the car for free!
As I haven't yet purchased a CX-5, how many quarts of oil does it take?
I ask because if it takes 5 quarts, then having the Fumoto valve adapter would be mighty efficient in that you could drain the old oil straight into an empty 5qt oil jug (from your previous oil change) instead of having to use a drain pan.
On ramps and letting it drain for an hour mine takes around 5.4 quarts to get to the full line on the dipstick.
Someone had mentioned that the thread of Fumoto oil drain valve is too long and it sticks out inside of oil pan. This prevents oil and debris if any to drain out completely. This is what he had found out after he took off the oil pan. I'd not use this valve just for this reason and the oil change on CX-5 is already the easiest you can find.10% off with coupon---> FUMOTO10
http://www.qwikvalve.com/
You once drained the oil overnight and I bet you definitely wouldn't like Fumoto valve preventing the oil to drain out completely to the bottom of the oil pan... BTW, I'll use Mazda oil filer for my first oil change too.I can't dispute whether Fumoto valve does or doesn't t allow the cleanest possible drain but I rely on my OEM Mazda oil filter to address that concern.
Hey guys, I came across a review on Amazon that brings up an issue with this valve. Below is the key part of the review:
A few months later, I went to replace the oil pan gasket so I drained the oil using this valve and removed the bolts around the pan. I noticed that when I tilted the pan, more oil drained even though the drain is located at the very lowest point in the pan. Then when the pan was removed, I saw why this was happening. It did not drain all of the oil. The valve extends into the pan.
The drain valve threads into the hole in the bottom of the pan, but it also extends through the hole, in my case by about 3/16". So when you open the valve, all but the last 3/16" of oil is drained, not ALL of the oil. Also, any thing heavy (carbon chips, metal chips) stays in the pan instead of draining out with the oil.
https://www.amazon.com/dp/ (commissions earned)
By looking at the thread length of the Fumoto valve I can contest that it is definitely longer than the thickness of the oil pan and will extend through the oil drain hole.F-106 w/o adapter
Given the concern for not getting all the oil out of the oil pan, I cut about 1.5 threads off the valve after doing my best to measure how deep the threaded part of the pan is. The brass is soft and I was able to clean it up using a small file. I'm looking forward to the next oil change as it should be easy.
Thanks to whoever suggested using plastic shopping bags around the oil filter. That worked great!
