what was your fuel setup previously and what do you plan on using for 30 psi?
I will not be running 30PSI, but if I wanted to, the motor could stand up to it. I will only be running low 20's PSI. I had the stock fuel setup before with the MPI tuner and the J&S. It only went lean when it was below 50 degrees out and only over 13PSI with the Nick turbo.
I could see the AFR go to 13/1 and then the cut would kick in. I could remove the cut with the MPI but I chose to leave it in place. When it was hot out I would never hit the cut.
I have the extra two injectors now that will be welded into the cold pipe so fuel will not be an issue.
