my clutch is on its last leg... looking to upgrade when i replace. i had an exedy stage 1 on the msp for a few weeks before i totaled it, would it be worth going this option again? also, thoughts on a lighter flywheel and msp lsd weld?
also need to find a new solution for the turbo oil return. i am using the recommended setup from the "thinking of turbocharging your p5" thread, with a high temp silicone hose mated with a fitting welded in my oil pan. i had it welded as high as possible but it is seeping out oil increasingly faster now between the fitting and the hose. tried a hose clamp with no success. i don't have the windage tray, could it be i chose a bad spot to weld the fitting? i did it opposite side of the drain plug as high as possible and the nipple is parallel to the ground.. thinking maybe it should be angled up. anyways i dont know the resting oil line in the pan. what did you guys do/what would you recommend?
additionally on the list of things to look into...
--- headlights cutting out at 5.5k+ rpms... battery is new, i think it must be alternator? no idea. i have new battery terminals and a 1/0g wire kit to install in the bay, maybe that will help
--- not building boost beyond 1-2 psi. thinking it could be wastegate actuator improperly aligned (rod sticks out too far, seal/flap can't close to build pressure?), bad silicone coupler connection, bad ebay type rs bov... idk yet
