My owners manual states that due to very high voltage danger , these bulbs should only be replaced by the dealer. So is there a special procedure involved to do this or can we do it ourselves..I've never had xenon lights before, so this is all new to me. (dunno)
Man it woulda been nice to have xenons from the factory on the 2010 MS3s...
But where dose this high voltage danger they speak of exist during bulb replacement ?
ehhh...not really. I spent $50 and put a set of DDM slim ballast 4500k in there and it looks and works great. Factory option would have been $1k at least.
I've had my DDM kit for almost a month already. 4500K as well. It's nice, but the light projection isn't as good as it could be. The outline of the 2 headlights closer to the car is slightly distracting at times. Guess I've had 2 sets of factory HIDs with projectors made for HIDs (RX-8 and MS6) and that's just what i'm used it.
Didn't really help with the clips for the connection to the factory harness being backwards, causing you to have to cram it in the harness incorrectly for it to work. Didn't instill the most confidence I guess.
Rather than cram it in backwards, simply grab some needlenose plyers and push the pos/neg wires out of the aftermarket harness, then put them back in the harness the other way. Takes all of 2 minutes and then you have a nice plug/play harness that clips and unclips properly.
I worked at that for a good 5 minutes and didn't think they were gonna come out. I wasn't sure exactly how they were held in the harness, and rather then possible break something off, I just flipped it around and made it fit. It wasn't overly difficult...just not as smooth as I thought.
Had I known BEFORE I ran the ballast, ignitors and wires, I would have tried something different. However, by the time I realized that the kit was NOT gonna plug and play factory, everything was routed and all the zip ties were already in place, giving me an insanely small area to work with.
I've seen similar harnesses before, but never understood exactly how they clips are attached.
Well, the place I bought them from was here.
However, since then, i've seen an almost unbelievable deal found here. This place seems to be a direct supplier, and better yet, their shipping it about 1/2 of what xenonexpert is. On sale for $50 plus $15 shipping puts you at only $65 OTD for a plug and play HID setup.
Good gosh...I mean you can't even touch that price. AND a lifetime warranty on every component, yet to boot!
You're going to get a better light spread with an OEM HID setup than putting an aftermarket HID kit into the halogen projector. Different optics are used for the HID projector setup which creates a more even light spread without glare and hot spots.
But there's no denying the allure of putting in an aftermarket kit since they're TONS cheaper I had an aftermarket HID kit once in a halogen projector setup, and although it looked good and was a noticeable improvement over the halogen bulbs, I could definitely tell the difference between its light spread compared to an OEM HID setup. I also had to modify the cutoff shield to minimize the glare for oncoming drivers.
