Justin, I hope you get it all worked out. There's got to be a solution to your issue. I just wonder if this is the beginning to more "scrutinizing" of your build from your local competitors.
Keeping my fingers crossed for you.
Van (looking forward to competing against you and your protege in Lincoln)
My local guys know what I'm up to. I want the "scrutinizing". I want there to be no stone left unturned when I get to the big show. If there is a question about something I did I want it out in the open as quickly as possible. I already fixed one issue that was noticed involving my aluminum shift linkage. I replaced both the linkage and the stabilizing bar with aluminum pieces, but the latter is not in the rules and therefore not allowed to be changed. I went to the junkyard today and pulled a stock one to install. My brain solves one problem and then forgets about it. I simply implied the wrong thing about the linkage allowance and then moved on to another project never to question it again. I'm glad someone else did.
