jonlong said:
what's the difference between winter gas and summer gas?
Winter gas has more additives, but I'll let someone with better knowledge handle that question... I'm gonna post my results from my ECU reset SO FAR. I reset it this afternoon and then let it idle for 10 minutes. I drove the car several hours later after work. I wasn't sure what to expect, but here it is so far:
(car is AUTOMATIC, currently calculated at dismal 16MPG)
- the car was much more responsive, even at -15 degrees celcius! Just lightly touching the gas pedal made my RPM gauge jump. I didn't have to press as hard on gas pedal to get car to move.
- car now moves a touch faster when releasing the brake pedal from dead stop. It used to crawl very slowly. It's now faster, even when crunching through thick snow!
- car doesn't seem to slow-down as fast while driving and releasing the gas pedal
- it seems my car is much quieter. I'll know tomorrow for sure, but as it was before the ECU reset, I would hear my car idle from inside my house with the doors closed when starting with my remote starter. It would sound like deep bass. right now (maybe cause car hasn't cooled long enough (only 2 hours)) I can barely hear my car while I'm standing right beside it.
- My RPM gauge needle used to be pretty damn stable at idle, but after ECU reset, it bounces slightly up and down (like +/- 1 mm). From what I've read, this should go away. Seems alright though. idles at around 800RPM.
That's it so far. I'll post my gas mileage next week. So far, the ECU reset looks very promising in my case. After all the maintenance I've done, how much lower than 16 mpg can I possibly get??!! OK, later!
