I believe it is because of the working pressure demands of the "Direct Injection". Most standard EFI works around 28 psi to 50psi. The direct injection as you know is almost 2000 psi. at times. The DI injectors need to have enough pressure to spray directly into the combustion chamber (high pressure environment) unlike normal EFI which spray into the intake runner / port.
BulldogSRT
