Hi
My protege has 90100KM on it & the check engine has turned on, (at 82,000KM I did a tune up = pvc valve, spark plugs, air filter, cleaned injectors, oil & filter change, trans fluid & trans filter change). I've checked the oil & trans fluid & they seem OK, can anyone else suggest what else they think it could be, that would trigger the check engine light?
Thank you
Thank you
