Why am i losing Oil?
dmjddm9999
2001 mazda protege mp3
Hey guys. About a month and a half ago i had a shop install sr motor soprt cam gears and jdm camshafts in my mp3. When i went to pick up the car they told me to change my oil immediately, so i did that same day. While i was driving today i noticed my oil light on. I checked my oil and saw nothing on the dip stick. I then drained the oil and noticed that there was only one quart of oil left in the car. I can't figure out how my car could have lost so much oil in only one and a half months. I only put about 1000 miles on my car since they installed the cam gears and camshfts. What could be the problem?
Did you notice any leaks? Was it smoking alot? I would think any one of those would be very noticeable. You did go through that oil pretty fast!
does your car have a turbo on it? or forged pistons? or a puddle under it? or oil all over the bottom of the engine?
another thing to check it when you first start the car in the morning, does any oil-like stuff come out of your exhaust pipe.
i did start noticing that the car does smoke a bit wen i down shift. But no i havent noticed any leaks. I dont have a turbo or pistons.
That sounds like it's burning it then. I would think it would be smoking like crazy if you were losing that much oil!
no, it doesnt smoke at all. I just noticed that wen i down shift without pressing the gas peddle to slow my self down, i would smell smoke.
i checked the coolant and it looked pretty good. I guess i may have to flush the coolant and check it thourghly. Thanks for the help
LOL it's and FC and the metering pump is bad...
How about the plugs, if your burning oil you'll see it on there. You may not =notice to much smokre at first because you have a cat that will clean most of the exhaust up. You do have a cat right.
Latest posts
