Wheel Spacers + Stock Rims
JayG1989
Contributor
2003 Mazda Protege5
Anybody using the combination right now? I'm dropping my car next week and then I want to widen out the wheels so that they're flush with the fenders. Just wondering if anyone is and what size they're running.
the max you can run on stock studs is 8mm, if not you need extended studs! I would suggest finding different rims with a more suitable offset!
I've been running 15mm spacers for almost 2yrs with zero issues. Make sure if you go over 10mm to buy the spacers that come with their own studs. Also, make sure they are HUBCENTRIC.
However, if you are boosted, I would also recommend getting the correct offset wheels instead of wheel spacer.
Like said above, my 8mm are fine on stock studs and wheels.
