hello all i am in need of new tires what is the biggest i can fit on my 16 inch stockers with no rubbing im currently dropped on h&r springs witch is about a 2 inch drop i believe...i want a beefy tire
215 fits...I run 215/40s on stockers. It's the absolute widest that will fit on stock rims. 215/45 fit as well, but I'm not sure about with your drop...I'm running a stock suspension.
You might be able to squeeze a 205/55 in there if you are looking for meatier but may have some rubbing issues, especially in the rear with your suspension set-up.
if i get 215/40's will i have any rubbing issues with my drop im dropped 2 inches i believe i don't want to have rubbing if im going to but expensive tires
215/40's may be ok...worst case scenario you'd have to roll your rear fenders a bit or might be able to get away with running some neg. camber instead but this would affect tire wear...so?
I must say that you have me a bit confused. In your first post you mentioned that you wanted beefier tires which is why I suggested a possible 205/55 without issue. Now you mention a 215/40....why not go with a 205/50 which offers a good 1/2 inch of extra sidewall, will fit the stock tires just fine and will not affect your speedo as much as the 215/40?
i have 205/50 on there now fusion hri tires but they absolutely get no traction the way i drive and if i plan on adding more horsepower then im going to want a tire that is durable enough for what i want.. one of my tires blew so right now i have three hri's on there and 1 falken not sure of type but its a 205/55 and it fills up the rear nicely with no rubbing am i going to have a problem running 205/55 on the front due to the tires turning?
I know your talking 16's, but I put 205/50/17's on mine that I got from a Mazda 3 and they fit, but are tight. They are maybe 1 inch to 1.5 in taller, but they fit.
