What is the bolt pattern on our 5s?
MD5
06 Carbon Gray Touring 5
Title says it all.
I wanted to look at wheels, but don't know the bolt circle pattern. Anyone know what it is (5 by XXX mm)?
Matt
It this the same as HONDA 5 bolt pattern then ? I have a set of 17 in fitted for my Odyssey before..that i wouldn't mind using on the 5 ...
Can anyone confirm this ?
Newer Honda Odysseys use a 5 x 120 bolt pattern. Mazdas use 5 X 114.3. I believe some Toyotas use 5 X 114.3.
Check out tirerack.com or http://1010tires.com/ to check out whether a particular wheel fits your vehicle.
Cheers,
martman
Latest posts
