Either you guys don't know how to calculate mpgs or you drive like grannys/drafting behind a semi. No way you are getting over 30mpg on it.
Intakes leaking.
Alright I got a problem, not on my msp but on my other protg. I took out the IM to replace the torn rear engine mount and put everything back.. only thing I replaced on the manifold is the gaskets, everything was working fine before and I cant see any issues with vacuum lines or anything not plugged in. I also don't have any CEL but whenever I start it theres a loud screeching sound coming from the manifold area.
video :
http://www.youtube.com/watch?v=b928MPOJpnc
Im quite baffled by this. Anyone have any idea before I take it out again?
You've got to realize that I've pulled an FS out of the BJ platform about 15 times between two of my cars and a friends car, plus I have a shop to use 24/7 with all the required equipment and tools. Plus a friend was helping. At this point I don't even have to look at what I'm doing... I just grab all the tools I need and go at it. And the crankshaft is scarred. Going to put another one in instead of machining.3 hrs? That's not bad at all! I'll, unfortunately, have to be in the same boat soon. How did the crankshaft fair?
This is why I don't understand why you keep blowing them up
I'm hard on cars. And ,unfortunately, the FS isn't that great of an engine to take the Preferio abuse. I would be okay if oil starvation wasn't an issue. I'd say after putting it back together this time it'll be gone in the spring either as it sits or with a stock bottom end.
put a KL in it and turbo. then be hard on it. Challenge set
or a bp? why not? haha
All of your motors had the stock oil pump/pickup setup? No doc B?
You certainly defy logic, my friend.
