so here it goes, and if i missed this in my search my apologies;
the engine is making an odd whirring/ clicking sound, i would best compare it to these spinning wheel boards you see at the fair with the plastic clicker that hits the numerous pegs/ nails around the circle. at low rpm, sound volume is the same, faster the engine turns, more rapid the sound, roughly the same volume. So I'm thinking the worst, but here are some odd points: No check engine, no oil in coolant or vice versa, drives normally, changed oil - no metal, no smoke in enginebay or out tail pipe, rock solid idle at 800.
Anybody have thoughts on what this could be i went under the car and it seemed slightly louder underneath, but it could be me...at this point im thinking either windage tray, maybe i spun a bearing, I'm getting more confused as i investigate.
