Twice now while driving I have slowed down to make a turn or come to a stop, push in clutch and shift into lower gear as i near the stop or the turn, and all of a sudden the car dies as if I had stalled but it starts right back up. I have not had a chance to check fuses yet so other than that i have no idea what is going on.
New problem that i noticed last night, while driving, even out of boost or just getting near boost my car is stuttering i push the gas it goes but you can feel it slightly stumble. I checked all the charge pipes and vac connections but I have not found anything to be loose. my idle vac pressure is fluctuating between 19 and 21, sometimes at idle it reads 19 or just under 20, sometimes it reads 20 and sometimes it reads 21. Im pretty sure its not the wga since mine is still pretty new and i dont really get on the car all that much plus when it was running fine i could boost and it did not go above 7
I dont have alot of time to look for everything and anything, im in the middle of finals so any clues that can narrow down my problem are appreciated. thanks
