Alright so I had the hood up on my car a few days ago. (checking fluids, cleaning battery terminals, nothing really mechanical) I left the hood up thinking nothing of it and went inside for about 15 minutes. Keep in mind I live in Florida where the weather is extremely unpredictable, anyways I stepped back outside to find a heavy drizzle rain shower. I quickly shut the hood and went back inside. Later that evening, about 5 or 6 hours later I ran to the store to pick up a few things and on the way my car started chugging horribly. acceleration is very slow and sluggish. it just didnt want to go. If I let the car idle the RPMS drop to about 3 or 400 and then immeadiately jump up to about 1200. Idle is rough, it has stalled once and comes close to stalling often. I first thought water may have got into my intake filter, so I pulled the spark plugs, which seemed fine, not wet or fouled. I tried turning the motor 3 or 4 times for about 15 seconds to see if water was in the cylinders and I couldnt find anything. I then drained the oil and put new synthetic oil, oil filter, and brand new NGK copper plugs and gapped them to spec. also put some fuel/injection cleaner in the gas tank. (it says it also helps seperate water if present) I started the car up and it ran smoother but still sounded like it was missing. let it idle freely for about 10 minutes then took it for a 8 mile ride. THE CAR RAN PERFECT! no hesitation or stumbling, good solid idle, and overall sounded and felt great. I wake up to go to work this morning and the car is back to running horrible. Has absolutely no power it stumbles and jumps around irrationally and sounds like the motor is missing. There is no ticking or knocking noticeable in the motor but I dont want to keep driving it and potentially cause further damage. I previously had a CEL for an exhaust 02 sensor, but the car ran fine since ive owned it. What else do you all suggest? what else could it possibly be? could the wires and coilpacks of gotten wet and caused damage to them? Im clueless and kind of stressing it because its my daily and need transportation for work.Sorry its a long post, just trying to be as descriptive as I can. Any and all help would be appreciated. Thanks guys.
