Yaegs4life
- 02 Protege 5 classic red
the highboost kit ...sorry
Yaegs4life said:Is the hiboost kit safe to run on a stock p5 engine and daily at that?
jaje said:correct me if i'm wrong but didn't the first 2 hiboost kits blow their engines in a short time?...i got the first wagner kit and paulmp3 got the 2nd and we're still going strong even with real road track racing (30-40 minute wot racing sessions at 7psi)
YP5 Toronto said:Sorry if I sound pissed (most will agree I'm usually quite laidback).... but there is too much Male Ego Posturing going on lately "my turbo is bigger than yours".
i was only referring to the first 2 kits sold by hiboost
Pirana said:Those would be me and Deckedout, none have blown engines. I just want to make it clear.
YP5 Toronto said:In general...the Mazdaspeed Protege had THE EXACT same internals as the P5 (contrary to some beliefs that it has strogner internals).
DooMer_MP3 said:I'll be going with the wagner kit myself. For the cost ($3250), you get a pre-tapped oil pan, pre-assembled mani-turbo-wastegate-downpipe WITH the wastegate pipe welded into the DP. And it looks great and seems to have good reliability. All I want is some more umph to my MP3. 6psi should be enough, and I'll be throwing a J&S Safeguard in there to make sure timing is proper. Fuel is only half the tuning, well maybe 75% of it . Timing is also a big key in engine longetivity.
Chris
sicp5 said:Do you not need the J&S with the HiBoost kit?
