MZ ZOOM - How many miles do you have on your car? I got the same codes, but I was getting those codes before I put the stix in. There is a known problem with coil packs getting a little frisky around 70k miles. I'm changing out my coil packs this weekend. I also got a "high idle' code, but that really isn't surprising seeing as I idle at 1500, but I think it's from some spacers that I put in on the same day as the cams.
Sweet! Good news!
Any idea why the UDP was interfering?
The R&R UDP has a stock pulley that has the "tooth plate" bolted too it. The holes that the bolts went through were wearing on the tooth plate and thus there was an incessant rattling coming from it.
Could you clarify what you mean by this?
Sorry, I must be dense...(deadhorse
I am really interested in knowing since i was planning on having the RR UDP in when my cams are getting installed.
the shims i needed were 4@3.500mm(kj01-12-597), 1@3.450mm(kj01-12-595), and 1@3.396mm(z502-12-593)
i got the car out of the shop. it definately needs some retuning. spent only a little bit of time on it tonight. the idle tends to jump around. when it idles flat @ 1250, she's a tiny bit lumpy. she runs pretty good and smooth from about 2250 to 4500 then it literally hits a brick wall. similar to hitting the rev limiter. it blips lean breifly but would blip a little lean the odd time WOT before the cams. so i don't think the tune is doing it. i'm wondering if the fact that the overlap is setup for FI is causing my issues since i'm still NA.
Lordworm, can you get back to me on what i need to set my cams gears at so the overlap is the same as the NA cams?
