I posted this before but don't know where exactly. Here it is again. From SU forum:
During the install, make sure to reset your ECU by removing the negative battery terminal for at least 20 minutes.
Before tuning the valve, you should allow the valve to "break in." Give it a few weeks before assuming that the valve needs adjusted. We set the valves here so they should be pretty close to the ideal setting when you guys get them on to the cars. However, each car/mods may require the valve to be fine tuned a little bit. Do not do it right away, give it some time and don't forget about resetting the ECU.
Hope this helps.
