sometimes yes but even after heavy boost the turbo itself doesnt get really hot. is that because its massive t3/4 turbo?Are you beating on the car then shutting it off shortly after and not letting the oil cool down first?
No one asked why the **** he's using 15w40? Christ.
Off topic but alamo please tell me you have a boosted P5 in Edmonton. I would heart you.
I work in a turbocharger repair shop. 5W30 or 10W30 full synth is recommended most of the time.
I can make a very educated guess why your turbo is consuming oil. HOT SHUTDOWN!
It's probably not watercooled is it? NOt letting the turbo cool down before turning off the ignition causes heat soak from the 500-1000 degree exhaust components. The heat travels up the shaft and from the turbine housing to the center housing. This extreme heat soak causes the oil to bake (coking) in the center housing, causing the seals to wear, blocking the drain passages and other detrimental bearing wear. Continued hot shut down will cause premature failure every time.
Failures that cause oil consumption 99% of the time.
Any other questions?
If you dont have a gauge, you dont KNOW how hot it gets.
How about asking everyone else what oil they run... I plan to run 10W30 full synth.
Keep running what THE GUY told you. But seriously, you have a bigger problem and you better figure it out or you're soon not going to have a running car at all.
