AutoEuphoria
- '08 CPW Mazdaspeed 3
A little background first...I've tried a couple of different setups with my MS3, and have had very little luck in trying to get rid of 3rd-6th gear WOT knock retard. I've tried an AP with an OTS map, a manual boost controller with MAP clamp, and an AP with a modifed OTS map + other bits and pieces trying to keep knock minimized. Nothing has solved the issue at this point.
I have also had a slight issue with boost creep. I was originally running a Corksport catless DP/TP combo, but recently switched to the stock mid pipe (catted) to try to help with the boost creep. It's helped a little, but I was still seeing creeping past what I wanted.
OK, so in order to get this issue solved I'm taking my car to Pure-Tuning in Toledo to have it professionally tuned. If this doesn't fix the problem, nothing will.
My question is whether or not I should put the test pipe back on before taking it down there? Can they tune around the boost creep? I mean, I know it is caused by mechanical means...the wastegate getting overpowered...but is there a way to tune around it (like setting the targets low and accounting for the creep up to the actual target)?
I like the way the exhaust sounds with the test pipe, and I do have it sitting around collecting dust at this point. Just wondering what you guys thought.
