- MSP 1145
bump for anyone looking to take on this task? or post a link where this can be bought!
I'd gladly make it... just get me the plans.
twilight has the plans he says.. but what would you do about the motor mount and such?
My plan was to measure AWR's mount diameter, match it, and then just get AWR urethane bushings...
I've got a 95 duro awr rear... and after a couple months, the vibes settled down a lot, and I got used to it. Don't even notice it anymore.gotcha. we'll see what he says. everything i get MM wise, i wanna do 95 duro
i wouldnt put the bar behind the suspension either. think of it this way. when you're accelerating the wheel and suspension is wanting to pull forward right? if you have the bar setup at the rear and above the lower arm, as the suspension pulls away the abr will pull the suspension up and you'll lose traction. if you have it at the front of the car and the mounting point on the car above the mounting point on the lower arm, when you take off, the suspension moves forward and the bar will basically push the suspension down on to the road giving greater traction...ie the point of this
