tire rotation on 20's - how often?
tstex
Gentlemen,
Happy Holidays!
Is there a general consensus on how often we should rotate our tires?
If so, what driviing conditions or vairables would have an impact on rotating more or less often?
After I get some feedback, I will tell you what the dealer said.
I own a 2009 GT.
Regards,
tstex
the manual states every 5000 miles for heavy duty driving (defined in the manual) and every 7500 miles if not heavy duty. i don't go by what the dealership says...they're usually out to make money off of you.
Every 6,000 minimum. Remember we are driving over a two-ton vehicle and the tires tend to wear faster. Rotate them late and the wear will be uneven, especially the AWD version.
I do tire rotation myself.
Therefore, I often do that when I have time and/or see uneven wear starts to show.
I brought my car to NTB last fall to put on the winter Blizzaks for $20. They told me that they would rotate the summer and winter tires free forever more without a charge.
Also, my dealer provided me a letter when I purchased the car that they will rotate the tires free every 7K miles.
I rotate every 5000 to 7500 miles. I also check air pressure on all vehicles Sunday.
My .02C
Had my Pirelli STR A s installed and Mr. Tire recommended every two oil changes = 10K miles. Dunno if this is right, but will try. Maybe I can do it myself after 5K w/ 2 jack stands and the vehicle jack.
So far, I did mine every 10K (just checked my maintenance record).
It is exactly 2 oil changes since I follow the 5K oil change interval.
Factory Bridgestones? Those suckers wear fast, I would rotate every oil change ~3500-4000 miles.
-OR-
don't rotate them at all, that way you will have to buy new tires sooner, and you will be much happier! (although $800 lighter)
(drive2)
I did an oil change at a little over 5k miles, will do the rotation next week at about 6k miles. Not a huge deal, but we took the car to ADSS (Advance Driving Skills School) in October, so the corners got pretty worn, even though we were on a wet skidpad and autocross. My wife had a blast though, well worth the tire wear.
Latest posts
