M mp51987 Member : mazda protege5 swagon Mar 31, 2014 #1 How do i adjust the throttle on my 02 mazda p5? Its idleing around 500-700rpms.
V Vasy Member : 2012 Mazda 5 Mar 31, 2014 #2 mp51987 said: How do i adjust the throttle on my 02 mazda p5? Its idleing around 500-700rpms. Click to expand... You mean idle speed adjustment? It would be best to post this in the Mazda protege5 forum as it is a totally different car to what most have here.
P phunky.buddha Booga Booga? : DFW TX : No mo MZ5 want MX5 Apr 4, 2014 #3 Moved... although there's really not a spot for engine tech in the normal P5 forum as far as I can see.
H hornsfan10609 Certified Mazda Tech : 2003.5 Mazdaspeed Protege x2 Apr 4, 2014 #4 There is a problem causing the low idle, you don't need to adjust it you need to fix the problem. It could be a dirty MAF, vacuum leak, torn intake tube, dirty air filter, etc etc. First check for Check engine light codes and go from there.
