you can buy a regular 2.0L engine out of a 01-03 sedan/protege5 and swap over all the turbo parts. only difference is youll need to either tap the oil pan for the oil return line for the turbo. or use your main bearing support plate (if it is not damaged at all) from your old engine. since it already is tapped from the factory for the oil return. no need to specificlly look for an engine out of a MSP.
