I hope that some of the experts on here may be able to interpret my datalogs and give me some indications as to how my car is running. I'm a little concerned because I have been getting quite a bit of hesitation/bucking in 2nd-4th gears when I am WOT. My mods are as follows:
Mazdaspeed CAI w/air straightener
PG turbo inlet pipe
PTP restrictor pill
TurboXS catless downpipe
TurboXS midpipe w/Vibrant 3" hi-flow resonator welded in
Denso ITV22 one-step colder spark plugs
Stage 2 + SF 93 octane map
After I flashed the ECU with the current map, I drove it lightly for 150 miles to let the ECU learn the new parameters. I have attached 4 datalogs, a 2nd gear WOT run, a 2nd-3rd gear WOT run, a 3rd gear WOT run, and a 4th ger WOT run.
Please take a look at these. I want to make sure I am not running dangerous in any parameter and if so, what I can do to make things right. Also, if I need to log different parameters or under different driving conditions, let me know and I can get those ASAP. Thanks!
PG turbo inlet pipe
PTP restrictor pill
