Thank you for the offer man I got a heat gun and I don't think a roller can push out the fender above my d-bills lol if I hammer up and out it will force the bill into a large flareProtege03ak46:5951406 said:First on the list of body work lol it was not intended I did the baseball bat method that o.g.told me to try and that was my result...I drove the car while a buddy used the bat so I had no idea till one side was already done...
I'm going to pull that whole inner fender well out so the flare is smooth
Bro, send me like 40 bucks plus shipping and ill send you my roller and heat gun...
i think circuit is the closest to it maybe in size. But i dont know if the p5's have the same wheel wells as the sedan.cant really answer that, check the first page for a ballpark estimate
A 17x9 + 23 off set should fit with a 205 stretch and a good role and pull with like 3 or 4 degrees of camber right last time I checked ?
Or role and pull almost flare some one correct me if I am wrong
16x8 +0 would be the equivalent of 16x9 +25 correct? Or would it be +13 cause if its +25 then +32-+37 would be perfect for a p5 with roll and camberfunkalicious21:5953098 said:A 17x9 + 23 off set should fit with a 205 stretch and a good role and pull with like 3 or 4 degrees of camber right last time I checked ?
17x9 +23 offset will need a a good roll and a slight flare. It's highly advised to go with a 205/40 if you have 17" rim. The stretch will make the whole process a lot easier to get to where you want to be. +23 offset is pretty aggressive if you do not have the AAC Rear Link Kit, but still do able. From my experience, 17x9 +35 only needs a roll and fits perfectly with minor camber, 1-3 negative*(varies with stretch).
