Please post photos of the light pattern and brightness once you get them installed - I'm waiting with baited breath (also detail what position you found works best). Also which colour temperature did you decide on? 5000K or 6000K?
Now that the 2016 CX-5 announcements are out I see they now have LED headlights as an option on Touring and GT - I wonder what projector housing they are using for those - if it's the same as they used for the HID's, the same as they used on the halogen H11's, or another "all new" projector/lamp housing... and what the chances would be of a retrofit of those new '16 MY LED lighting systems on the '15s (obviously without the adaptive leveling/aiming functions) - so many questions... I may have to go visit a local lot that has a '16 CX-5 with LED lighting in stock in the next few weeks and take some under the hood pictures to see what they've done to implement them and then compare them to the standard Halogen setups.
IF the LMZ's look good, I will likely start on step one with the 4 emitter 5000K 4500LM low beam H11's. If they pass the muster, then the 9005 5000K 4500LM high beam retrofit comes next, finally followed by the inexpensive 5000K 850LM XB's on the fog lights (which I almost never use, but if all my others are 5000K LED why not finish the package... Ok... so I'll be spending like $600 on retrofitted LED lighting - but what the heck - if they look good, last a long time, and are even a little brighter with a little better vision than stock halogens all around I'm happy.
I'm in the same boat about spending money on LED's... except that boat has sailed a while ago I should have the Philips LED's next week.
