tapping into brake booster line?
dfsho
I am installing my hks ssqv and am re-doing my vac lines.
I have to tap into the brake booster line to run lines for my bov and bpv. (I am using 505s bov/bpv set up.
My question is how should I do it?
Yes, I know about the check valve but I can't seem to find it.
The line feels all the same through out.
I know about the vacuum block but it is rather expensive and I don't understand how to connect it.
The brake booster line looks to big to me for that vacuum block.
Any help would be greatly appreciated!
I was told there was a how-too but I could not find it.
Thanks!
Dfsho
When I had my HKS I just tapped it into the Fuel Press Regulator Vac source and it ran great with no stall issues.
Thank you!! all your help was greatly appreciated.
I feel dumb now. Its way less complicated than I thought.
Thats how you learn bro, by asking questions and doing the right research. I would also recommend the VAC block for convenience & reliability like the other guys mentioned.
