I'm dropping her on Monday evening to diag warmup pinging/pre-ignition.
I have not heard anyone on here with this problem.
Pings (sounds like marbles bouncing around in the top end) consistently, only under moderate accelleration, and only until the coolant temp reaches normal operating temp. Once it reaches normal operating temp, its like a light switch, it gets turned off. It does not start to go away as it warms up, no, it literally immediately ceases as soon as the needle gets to the middle. Doesn't matter what the temp is outside.
Have tried 89 octane for awhile at shell, that did nothing.
Have tried both oem and K&N filters now, and no difference.
Stealership basically stating that unless it is something inside the engine that the 60k warranty likely would not cover it. (B.S.).
