As soon as I turn the stalk to parking light the Tail Light Fuse will blow.
This Fuse is also linked to interior lights.
Things I have tried...
1) Replacing the fuse
2) Using a higher rated fuse (30a as opposed to the 15a) also blew immediately
3) Pulled the interior light dimmer switch, fuse still blows when this is disconnected.
4) Fortunately (or unfortunately, depending on how you look at it) I have another Protege. I took the TNS from the problem car and put it in the good car and everything still worked. So, it is not the TNS relay.
Any ideas?
Any ideas?
