I'm about to install mine under the passenger seat. There is ample space under the seat, so I'm gonna put it on 1 inch spacers to help with the airflow from the vent. Just so I'm not blowing hot air directly onto the amp if I have the heater on. Then again I live in so cal, so the heat isn't on very often in my car anyway
This has been a fun little process though since Mazda decided to make those bolts a real pain to take off. A few words of advice if you are going to remove your driver or passenger seats...
You need to unclip the connector under the seat that controls the airbag sensor. Make sure the car is OFF completely!! Better yet don't even have your key anywhere near the car just to be safe. You can also disconnect the negative terminal from the battery and wait a couple min before doing that. Make sure after you are done to clip the connector back in. Don't start the car up without the connector hooked in or you will need to go to the dealer to have them reset the airbag indicator light (read that on another forum)
The bolts are 10mm torx. Don't make the mistake I did though going to Home Depot and getting a universal socket (12 point) The 12 point will strip the top of the bolt. Make sure you get an E11 or E12 (more common) torx socket. You can find those at any auto parts store. I got mine at Autozone and ended up having to buy a set but it was only $8. You need 28 to 39 lb/ft of torque to loosen the bolts. That's not much and any medium to large socket wrench should give you enough torque with a little elbow grease. A tip i was told is spray a little WD40 on them too to help loosen them and prevent breaking off any metal.
