Installed the GT Spec front bar and it made much more of a difference than I thought it would. I definately have to get my rear swaybar hooked up again, massive wheels spin out of all the corners.
Nology wires in today - no instructions...Cruise brackets are removed due to the GT Spec bar, so I will have to be a bit creative with the coil relocation.
Rotas don't fit with the AWR coilovers...bought some spacers, but the rear are going to rub way too much, so looks like I am going to have to go to an 8" spring as opposed to the 10" springs I have now. That'll move the spring perch up and hopefully give me more room without the spacers.
Went ahead and ordered the 245/35/16s to get a little more room as well.
Tomorrow the TWM shifter goes in, and the Nology wires as well. If I feel a bit energetic, the Pulleys will go in too. I have to make a new mounting bracket for the Oddessy battery, I want to lower it down by the "frame rail" even though it's only @13lbs.
gonna work on a new fuel map for the AFC2, need to richen it up a bit on the top end, so after that, the pulleys, the wires and new plugs and we'll see if we can hit 200/210 at stock boost.
That's tomorrow though, tonight it's back to cleaning the house...yea!
Britt
