My car has been "stumbling" and running rough. It is most pronounced under load: ie starting from a stop, or just off idle while revving in neutral. It runs smooth if I hold it at 2-3000 rpm in neutral at a stop.
For the record, I have always had the low/bouncing idle issue. This is not the issue I am talking about. So it is not the EGR, a vacuum leak, or exhaust leak. It's something else.
I had the codes read and there is no code that would cause this issue.
I bought a replacement coil pack (store only had one in stock) and swapped it around. It made no difference.
Any input? Thanks.
Any input? Thanks.
