sherman banks
I've read up on a few of these other "cars not starting" threads, but am unsure of what the issue might be with mine. The car has a good battery, interior electronics on fine, but when turning the ignition I only get a "click" sound. Not sure if it's the starter or some other mechanism causing the sound but the motor is not even attempting to turn over. So from what I've read it could be the terminal connections, starter solenoid, or just a bad starter. Any idea where the starter solenoid is? Is this the switch located in the steering column? And any way to test it without a voltage meter? The car hasn't had any issue firing up before so I'm kind of stunned it just wouldn't turn over last night. Thanks in advance for your help!
