slammedmsp
- 2003.5 MSP
Question, I need to replace my msp's turbo and found an sr20det garret t25 for a very good price, will it bolt right up or will I need any modification ? Has anyone used this turbo?
talk to scmp3....hes got a silvia t25. idk if he had to do any mods to make it work though
no problemoThank you for refrering me to him, he explained it to me very detailed
Which adapters? I wasnt informed of this lol and did that happen to yours?I bought a silvia T25 thinking it was the same. It is actually smaller than the MSP T25. You need to buy adapters, clock it, and possibly mod the WGA. They are also journal bearing instead of ball bearing, so they can be rebuilt but they are much more prone to being damaged by compressor surge.
Oooh, thanks for the heads up man, anything else I should look out for when doing this?For the turbo flanges. For instance, the MSP T25 has a 3 bolt outlet whereas the Silvia T25 has a 2 bolt outlet. They can be found on atpturbo.com but I think they cost about $30-$40 each.
i have mine all set up and ready to be installed
just needs the 3 bolt outlet and 2 bolt inlet adapters for the compressor.
i used an atp wastegate and msp wastegate bracket with 2 of the holes drilled out.
reclocked
and braided lines with proper restrictors
they are the same size as the MSP turbo but not ball bearing. a little less spool and a few lesss hp(1-3 maybe) but easily replaceable and dispsable
here is a pic of it set up with the msp manifold, atp adapters and CS s-pipe
its not on yet because of school. but a few weeks and i should be able to see how well it works
Thank you really appreciate the info, where'd you purchase all your gaskets and the 3/2 adapters are for the outlet right?im in the process of turboing my MP3 so i have to install everything(oil feel, return, oil pan, fmic everything)
for gaskets you will need to pull off everything i have showed you there off of the car. so exhaust manifold, 4bolt t25 gasket, 5 bolt outlet gasket and the 3 bolt gasket between the s and j pipes.
the 3/2 bolt adapters for the sr20 t25 from stp came with a rubber compression gasket so you should be fine there.
you will need gaskets for the oil drain return fittings i believe as well and crush washers for other things. not too sure on the stock msp stuff
Thank youYou can pick those up at ATPturbo.com
