- 07 Speed3, Cosmic Blue
I live in VA and we have those 30 deg to 60/70 deg temp changes alot this year.
The one big thing I noticed is that mid to upper 60's this thing WANTS to GO!!! Not so much in the lower temps.
Last Monday (18 Feb) I drove from VA to RI. I was seeing upper 60's in NJ & NY. Hit the gas (75 -100% throttle) and the damn thing would spike to 19 and settle around 17.5-18psi. Only mods: Cobb SRI and Dogbone.
I did this a couple of times just to verify what I was seeing. I could not do it too many times, because we all know that at 70mph that much throttle for 5-10 sec will put you in the 100+ range.
Coming back the Thu after, the outside temps hovered around mid 30's. Noticed that the car did not pull and never saw as much boost. As a matter of fact, I had several instances where boost went to around 10psi and started stuttering (fuel cut?). In one instance, I heard the turbo spool, saw the initial boost and got the stuttering. I kept my foot in the throttle a bit and noticed the spool sound (Cobb SRI) yet my gauge dropped to 15-20 in of vacuum.
This being my first turbo car, I am still learning whats normal and what the warning signs are. My concerns are the upcoming summer and what the car will do then (monitor, monitor, monitor!). I just know that she has a lust for those 65-75 degree temps and at those times desire to sate them for her.
If anything here has been answered before, I apologize. I just think that the mods we do during the winter (for us that have some good temp variances) need to be closely monitored when the weather gets better.
