Spark plugs for a 98 Protege LX 1.8L
TheAvatar
Hello All,
I never got a users manual for Protege and have no idea as to what spark plugs I need to get.
98 Protege LX 1.8L
Thankz
TheAvatar said:
Hello All,
98 Protege LX 1.8L
Thankz
1998 MAZDA PROTEGE 1.8L 4-cyl VIN Code 7 BP DOHC
FILTERS
Oil Filter......SDF13
Air Filter......AF411
Fuel Filter......GF234
PCV Valve......HV115
Trans......TF118
BOSCH SPARK PLUGS
LX
Wire......B09134
Plug......B4418
ES
Wire......B09134
Plug......B4418
BOSCH WIPER BLADES
Driver side......B40921
Passenger side......B40918
CHASSIS LUBRICATION
0 Fittings, 0 Plugs
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......SL
Series 2000 Synthetic 0W-30 Motor Oil
SAE 10W-30 Synthetic Motor Oil
SAE 10W-30 XL-7500 Synthetic Motor Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
Above -13F......10W-30[1]
Below 32F......5W-30
Manual Transmission,.....GL-5
Above 10C......80W-90
SAE 80W-90 Synthetic Gear Lube
All temps......75W-90
Series 2000 Synthetic Gear Lube
SAE 75W-90 Synthetic Gear Lube
Manual Transmission,.....GL-4
Automatic Transmission.....AF3
Synthetic Automatic Transmission Fluid
Automatic Transmission.....MA[2]
Fluids
Power Steering Fluid.....AF2
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3, DOT-4 or SAE J1703 - Not Available Through Amsoil Click here for more information
Clutch Fluid.....HB
Power Steering Fluid.....MA
Brake Fluid.....HB
Clutch Fluid.....HB
1. 10W-30 is preferred.
2. Alternate lubricate.
CAPACITIES
Engine, with filter..........4.0 quarts
Cooling System, Initial Fill..........6.4 quarts
Automatic Transmission, Initial Fill..........4.2 quarts[1]
Automatic Transmission, Total Fill..........5.7 quarts
1. With engine automatic transmission operating temperature, shift through all
gears. Check fluid level in PARK and add fluid as needed.
TORQUES
Oil Drain Plug.....22-30 ft-lbs
Manual Transmission
Fill Plug.....29-43 ft-lbs
Drain Plug.....29-43 ft-lbs
CAUTIONS
ENGINE
Properly center oil drain plug gasket in
crankcase pan depression or an oil leak
may occur.
TRANS/DIFF
To check manual transmission level, remove
speedometer drive from the transmission.
Level should be between upper edge of gear
and lower edge of first flange.
SERVICE INTERVAL
http://www.amsoil.com/lit/g1490.pdf
Latest posts
