fluid malfunction!?
so i'm leaking coolant... dirty nasty coolant. simple enough right? WRONG.
i have pinned down a possible origin, but it seems strange to me. picture this:
you have the little white plastic resevoir... look just to the right: there is a chunky silver/grey 3 sided square brace thing... now look just under that: you should see a sliver round piece (mostly like a donut) with two bolts coming out of it...with a circular piece of rubber inside (like the donut hole)..... its molded/welded to the motor....perhaps this is a motor mount???
the underside of this piece (where you see like a 2.5 inch black horizontal bar) is where the leak looks to be coming from... from where the rubber meets more metal,dripping all down the frame and onto the splash shield at the bottom of the bay.
its really dirty by the time it leaves the part in question... the only thing giving it away as coolant is the smell.
your thoughts? have you experienced this?(uhm)
thanks guys... forgive my ignorance...
