Reserved #3
Mechanical Information:
Motor: JDM KLZE Straight Neck
Transmission: 1998 626 V6 Transmission
Mounts: Driver Side; Protege, Rear; Protege w/ modified bracket, Front; MX6, Passenger Side; 1.8 Protege
Exhaust: MX6/626/PGT Pacesetter Headers, Shortened Protege Mid-Pipe, MSP Axle Back
Radiator: MX6 w/ modified lower mounts to sit in the protege radiator support, MX6 Hoses
Axles: 03 MSP Axles, 1994 MX6 intermediate shaft w/ modified bracket to bolt to the KLZE
Power Steering: New Suction hose cut to length, Protege P/S Reservoir, Protege Pressure Line, and Protege cooler lines and cooler.
Intake: Modified KL31 Throttle body w/ Protege throttle cable mount to clear the master cylinder, MX6 ebay short ram, Protege Lower section CAI w/ AEM DryFlo Air Filter
Battery: Modified Protege battery tray, Braille B2015 15lbs Slim Battery, Universal Battery Tie down rods and 2nd Gen Protege Tie down cut to length
Heater Hoses: Cut to length coolant hose of the correct size
Fuel Lines: 3/8 Fuel lines cut to length
Brake Booster Hose: 3/8 Hose cut to length and a check valve inserted to allow vacuum only
Shift Linkage: Protege Shift Linkage, however, this changes the angle of the shifter int he car slightly. Others have used PGT linkage to get the correct angle back.
Electrical Information:
1994 MX6/626 ECU Pin Locations / Wire Colors Used
22-Pin Connector
Pin 1: Constant 12v Power - BL/R
Pin 2: Start Signal Input from Ignition Switch - BK/R
Pin 11: Ground - BK
Pin 12: PCM Power - R/BK
Pin 20: Neutral Safety Input - LG/BK
26-Pin Connector
Pin 1: Ground - BK
Pin 2: Ground - BK/R
Pin 14: Ground - BK
Pin 15: Ground - BK/BL
Protege Wiring - To get the cluster in fully functional condition, aside from the fan relay, and fuel pump relay the motor should be safe to run without this.
Ground Fuel Pump Relay at ECU
Wire tach adapter to cluster and tach signal wire on distributor
Use Protege Coolant temp sensor in the second coolant temp sensor location (KLZE only), extend Protege coolant temp wires to sensor.
Use protege reverse light switch and wires.
Use a 98+ 626 Speed sensor and Protege harness to run the speedometer on the cluster.
Use an aftermarket thermostatic fan relay
Maintenance Information:
Oil: 5w30
Qty: 4.5qts
Oil Filter: MX6/626 filter
Gear Oil: 75w90
Qty: 2.9qts
Spark Plugs: NGK BKR6E-11
Distributor Cap and Rotor: MX6/626/Probe
Axles: MX6/626/Probe Intermediate Shaft, 01-03 2.0l Protege Axles
