Hello All...
Now, never having owned a diesel prior to my CX5, I have to admit to being completely unfamiliar with diesel technology. I am quite OK with four stroke theory, and turbo technology. My old CX7 was tuned by myself and ran extremely well.
This being the case, I have installed my old Dashhawk into my CX5, to get an idea on things like Load, Throttle Position, Boost Pressures etc. But in order to make some degree of sense with the readings, I need to understand better diesel technology.
For example, when idling, a petrol engine may sit around 12inHg, but my CX5 Diesel sits at 3inHg. This seems rather odd initially. I am not sure if it is a scaling issue with the Dashhawk interpreting the OBD data in relation to atmospheric pressure. Or possibly the fact that as I believe, diesels engines do not really use throttle plates to alter power. In the case there is no throttle plate, I can understand the idle "vacuum" would be very close to zero. Remember, that what we see as "boost pressure" is relative to atmospheric pressure.
The other issue I am trying to understand is the boost pressure specification for the motor. Unless I am going decidedly mad, I could swear I saw over 24PSI boost..!! In fact, the engine spent most of it's time in boost. Again, I'm not sure if there is a scaling issue relating to atomspheroic pressure. As in, deduct ~14.7...
Looking at the CX5 Diesel manual, there is a "Shutter Intake Valve." On first glance, it maybe typical a throttle plate assembly. But somehow I don't think it is.
Any ideas here...????
