don caballero
Hi,
I was able to remove my side motor mount (after using an engine lift to lift up the engine... there's nothing to jack it up by on the underside, cept the oil pan!), but I cannot push out the cast iron pin that bolts to the motor & goes thru the center of the rubber mount. I tried a break puller, but since the rubber's broken already, it has no hold. Same w/ air-hammer. Any suggestions? I believe my only hope is that it's a cheap dealer part, and I'll just replace it then.
Thx,
Don Cab
Thx,
Don Cab
