Hi all, I've got a 2002 protege with a 2.0 a/t. Recently I was pulling out onto the street and I shifted into low gear to get out and then back to drive. The O/D off light started blinking and it won't shift into 3rd or higher. There is no check engine light and I reset the ecu to stop the O/D light from flashing. I've found some things to check for but nobody had a similar problem with no check engine light like I had. Anyone else ever have a similar problem?
